New Scan Tool - Auto Enginuity
I have gotten quite a bit of PM's about this so I wanted to post up the info in full!
UPDATE - AutoEnginuity now supports CAN. Most of the newer 2004 vehicles now use CAN instead of OBDII. Please see the option below.
For more on FREE software updates and AutoEnginuity Literature, check them out at www.autoenginuity.com
What AutoEnginuity's ScanTool can do:
Read Stored and Pending P, U, B, C Trouble Codes (including 14,000 manufacturer specific codes)
Clear the Check Engine or Service Engine Soon indicator
View live vehicle sensors in a grid and graph format
View oxygen sensor live data and test results
View all 11 Inspection/Maintenance system test results
Unlimited logging of Diagnostic Trouble Codes and live vehicle sensors
English or Metric (SI) units of measure supported
Run and query specific component and system tests
View generic and manufacturer enhanced data on the same tool
Configure the interface to suit your preferences
Supports:
1996 and newer passenger vehicles whether it be domestic, Asian, or European.
SAE interfaces: J1850 (PWM and VPM) and ISO-9141-2
Requirements:
Differ for Palm, Pocket PC, an PC Based - SEE VIVID WEBSITE
The ScanTool package consists of:
AutoEnginuity's software
AutoEnginuity's OBD-II vehicle interface
Protective case
User Guide
Speed Tracer Stage I -- Free to all ScanTool purchasers!
SpeedTracer is a performance analysis software for your PC or PDA. Are you curious if that new part worked? Is your vehicle performing to its fullest capabilities? With SpeedTracer, we can help you answer those questions. Save hundreds of dollars running dynos on your vehicles. What's more, you can run the performance analysis at YOUR convenience--not regular shop hours.
What it can do:
0-60ft time
0-60 MPH
1/8 mile time
1/8 mile speed
1/4 mile time
1/4 mile speed
G Forces
SAE Horsepower
Torque
SAE Horsepower and Torque vs RPM graphing
Speed vs Time graphing
SpeedTracer doesn't use accelerometers, so road conditions will not affect your results. It uses the "rolling" chassis dynamometer method to measure your vehicle's horsepower and torque. You won't be required to start your dynamometer testing from a complete stand-still. Now you can perform your analysis in the gear that is best for your vehicle--not the testing equipment.
How accurate is the "rolling" chassis dynamometer method? Of the two methods (crankshaft or chassis) the "rolling" chassis method produces the most usable results. This method will show you what the actual horsepower and torque are at the driven wheels; after the frictional losses from the clutch/torque converter, the driveshaft, half-shafts, the differential, air resistance, and drag. We have tested and proven our methods accuracy through several tests against very expensive roller-based dynamometer equipment.
What sets our performance analysis software apart is that the results are corrected for environmental variables using the SAE J1349 standard and built in vehicle profiles.
Using the current environmental variables (humidity, elevation, and temperature) we can correct the results to insure the most accurate and consistent results. Correcting for environmental variables is not enough in the case of force induction vehicles. The SAE formulas are made for normally aspirated vehicles. We go one step further and correct for forced induction as well. Without these corrections your torque and horsepower readings would be inaccurate from day to day and region to region.
SpeedTracer makes inputting your vehicle profile easy because it has most vehicle profiles built in. If your vehicle's profile is listed, simply select it and begin your performance analysis. In case you have special modifications to your vehicle, you can change your vehicle profile to take those into account too. You can also create and modify vehicle profiles to suit your needs.
How does it work: 1) set the environmental variables so the proper corrections can be made; 2) select your vehicle profile; and, 3) run your vehicle to its full potential and see your results. It's that easy.
For pictures, applications, costs, and ordering, please click the link below...full screen shots are available as well
http://store1.vividracing.com/catalo...oducts_id=2840
Thanks!
Supports:
Requirements:
Protective case
User Guide
What it can do:
0-60ft time
0-60 MPH
1/8 mile time
1/8 mile speed
1/4 mile time
1/4 mile speed
G Forces
SAE Horsepower
Torque
Thanks!
