996 Forum 1999-2005
Shift linkage and play
Old Jan 5, 2005 | 02:54 PM
redduck996's Avatar
redduck996
Default Shift linkage and play
2 questions,
1. How much play should one have on the gear box or shift linkage? I seem to have alot of play in neutral(if that makes sense) and more then I think I should when it is in gear.
2. Does it matter where neutral is set or is it just a preference thing?
thanks
Old Jan 5, 2005 | 03:01 PM
Alon's Avatar
Alon
Is your car stock or are you running a short shifter of some sort?
Old Jan 5, 2005 | 03:09 PM
redduck996's Avatar
redduck996
Default re
stock as of today. B&M soon (hopefully)
Old Jan 5, 2005 | 03:11 PM
Alon's Avatar
Alon
Stock and you suspect that there is play? That's interesting. Have you compared to another stock 2002 and up 996 to make certain? Surely your car is under warranty still if there are any problems and if in fact there are, you may want to have them sorted out prior to installing the short shifter.
redduck996's Avatar
redduck996
I would think less play = tighter and more precise shifts right?
I remember reading a post somewhere about someone being super meticulist and had his shift adjusted bc it was 1mm off center or something like that..
Old Jan 5, 2005 | 03:13 PM
Alon's Avatar
Alon
1 mm off center? He's been admitted for psychiatric help and no one has heard from him since
Old Jan 5, 2005 | 03:25 PM
redduck996's Avatar
redduck996
lol...
Old Jan 5, 2005 | 03:27 PM
redduck996's Avatar
redduck996
Thats the thing.. I haven't driven anyone elses 996 and dont know if mine is normal or not.. To me, it's a considerable amount of play even when in gear. The shift just seems loose..Is this something that I can adjust or tighten up myself while i'm in there?
Old Jan 5, 2005 | 03:29 PM
Alon's Avatar
Alon
I don't believe that the factory parts are adjustable for amount of play or the position of neutral. The B&M should fix things up for you if what you have is in fact, normal for a 996.
Old Jan 5, 2005 | 04:02 PM
TT Surgeon's Avatar
TT Surgeon
Just put the BM in, you'll be fine.
Old Jan 5, 2005 | 04:06 PM
Eric - Plug Guy's Avatar
Eric - Plug Guy
Basic Sponsor
Couldn't agree more. Once it goes in you will see what you have. Consider the evo shift link too if you still wonder about loose linkage and breaking. Not mandatory, but a nice add.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring 6sp
2009 997 Turbo Cab 6sp
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
