996 Forum 1999-2005
GT3 engine in 996 ?
Old Dec 15, 2004 | 03:53 PM
MacFever's Avatar
MacFever
Default GT3 engine in 996 ?
Does anyone knows if it is possible to put a GT3 engine inside a 2002 996 C4 tiptronic ?
Old Dec 15, 2004 | 04:11 PM
TT Surgeon's Avatar
TT Surgeon
Yes, but you may have to change the tranny as well.
Old Dec 15, 2004 | 04:13 PM
Itzkirb's Avatar
Itzkirb
Since doing either will void your warranty, I would suggest Supercharging it. You'd get more power.
Old Dec 15, 2004 | 04:44 PM
MacFever's Avatar
MacFever
The tranny is the same as the 996TT tiptronic so it will cope !
I prefer the GT3 engine because of the conception (dry sump)
Old Dec 15, 2004 | 06:26 PM
penguinking's Avatar
penguinking
why not just add dry sump to the motor instead?
Old Dec 15, 2004 | 07:22 PM
blackcat's Avatar
blackcat
penguin,
Should I ask what happened to your WRX? Long and sordid story or sudden, abrupt ending?
Pete
Old Dec 15, 2004 | 07:41 PM
Dale Gribble's Avatar
Dale Gribble
Pocket Sand
if you can afford to do so, yes its possible (not sure if it will hook up to the automatic tranny tho) but the engine will fit (even into a boxter)... but its like a 60 thousand dollar engine....you could destroy 3 or 4 normal 996 engines for that price...
if you plan on keeping your car a long time, then sure, why not? but otherwise, you're probably better off just working with the original block. (RMS leaks are far less common then this board makes it seem )
Old Dec 15, 2004 | 08:49 PM
fahren affair's Avatar
fahren affair
unless you plan to race 24-hr enduros on slicks w/ a full-race setup, the standard integrated-drysump is enough. a blower is prob a better option than a transplant.
Old Dec 15, 2004 | 09:34 PM
Dale Gribble
Pocket Sand
^ he's probably right...if ur still conscerend...get the upgraded oil system option (gert @ carnewal has them i believe) and ur set...
Old Dec 16, 2004 | 02:45 AM
MJSpeed's Avatar
MJSpeed
The Rebel
It can definitely be done...the real question is why (since there much cheaper options out there), which brings me to the second question, how much are you willing to spend???
Old Dec 16, 2004 | 04:57 AM
MacFever's Avatar
MacFever
Thanx for the info guys
I think I will go for a 996TT tip ...
