996 Forum 1999-2005
TIPTRONIC upgrades?
Old Dec 14, 2004 | 08:37 PM
AD996's Avatar
AD996
Default TIPTRONIC upgrades?
My 99 996 TIP does not allow steering wheel gear activated changes when in automatic mode, but I read that the later TIP's allow this function post 01. Logically it must be software driven can the software be upgraded?
I have heard this is possible with BMW's transmissions where you can upgrade the chip in similar fashion to the engine managment system, of course this only holds gears in the BM's giving a sportier feel?
Has anyone done this or do dealers offer it?
Cheers
AFD
Old Dec 14, 2004 | 09:14 PM
smshirk's Avatar
smshirk
My 2000 996 does allow to shift up or down when in auto mode, but shifts back quickly unless you really get on it. I haven't done anything to it and i don't believe the original owner did either. I have all of his records since new. I thought it was supposed to. I also thought if PSM was turned off and in manual mode that the tip wouldn't shift on its' own, but mine does, just before redline.
Old Dec 14, 2004 | 09:49 PM
AD996's Avatar
AD996
In Auto mine drives just like an auto of course with the pedal tap/tap feature, it starts in 2nd and unless given some stick at take off stays in 2nd. In manual it starts in 2nd and I must shift to 1st in order to get on as you say, then it will hang onto a gear and only upshift at red line or close to.
Cheers
Old Dec 15, 2004 | 06:49 AM
MikePl's Avatar
MikePl
There is company called Rennsport Systems (porsche@rennsportsystems.com) who can make the modification to your tiptronic transmission. Unfortunately I got the following answer from them: " Due to the amount of work that the Tip ECU requires, at this time I'm only doing those when the engine ECU is done" The modification to your software supposed to make your shift faster.
Mike
Old Apr 23, 2008 | 11:07 AM
OCNYPORSCHE's Avatar
OCNYPORSCHE
I know this is an old thread. Has anyone upgraded their tiptronic to allow shifting while in auto mode? MY 99 does not allow this, but my Cayenne does and I understand that later 996s allow this too.
Old Apr 23, 2008 | 11:25 AM
Tippy's Avatar
Tippy
My old 2000 allowed manual shifting with the steering wheel buttons when in auto mode.
Old Apr 23, 2008 | 01:41 PM
ScottArizona's Avatar
ScottArizona
I'm surprised to hear that my2000 tips had this feature. Definately not the case on my 99 tip.
Old Apr 23, 2008 | 11:13 PM
Serenity Now's Avatar
Serenity Now
Same here, my 99 does not but I read that 2000 and newer do...
Old Apr 24, 2008 | 01:00 AM
htny's Avatar
htny
the only major change I'm aware of is in 02, when they changed over to beefier tiptronic S (from the turbo), I thought that in all the older cars you could use the steering controls in auto mode but that it would revert to auto in 8seconds
Old Apr 24, 2008 | 05:34 PM
GoodSpeed Sweden's Avatar
GoodSpeed Sweden
Mine MY2000 can do it.
Old Apr 25, 2008 | 07:44 AM
PorscheSki89's Avatar
PorscheSki89
I drove a friend's 993 (I believe 96) and it allowed manual shift from wheel while in automatic.
