Small oil(?) spots on garage floor.....
#46
Basic Sponsor
+.30 is the number they consider for engine replacement.
On mine, the maximum differential is .24 (10.16 - 9.92). Still within spec (under the .30 number).
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
#47
Basic Sponsor
Originally Posted by Scouser
I hear you can supply painted door key covers... I want some How much?
Email me if you don't see what you are looking for.
Thanks!
#48
Ok ok
Lets clear this clutch thing up........First off I am NOT the one who was under the car and said " Hey there is oil on the cluth" I know for a fact it was a tech who then inturn told the Service advisor, SO YEA RMS DO RUIN CLUTCH PLATES, Why would they replace NO CHARGE if it were my fault??? For the money this car was sold for , i should be able to beat it day in and day out, Some one said on the forums " That porsche is an SUV mfg making ageing Sport cars" SOOO TRUE
#50
By the way, my local dealer told me that if a particular car experiences the RMS problem three times, they have authorization to replace the engine because Porsche has not provided them with the tools needed to machine/modify/whatever the crankcase at the seal surfaces.
#51
Kil,
I feel for you man. So far I've been fotunate enough not to have a lick of trouble, and I do run it hard on a daily basis. Mine IS a daily driver/ tracked car with 24K on it and counting. What other car could you drive 5 hrs to watkin glen, run the **** out of it for two days straight, then load up your crap, turn on the AC/stereo and drive home like nothing ever happened. I love that car and would surely buy another.
Good Luck
Chris
Good Luck
Chris
#52
Originally Posted by RobynC
Cheers my friend...oh...and is it common to call ladies "mates" over there?
#54
I am not too familar with a area underneath the P-car. What is VarioCam? I notice oil sludge buildup around that area, pertaining to where the exhaust bolts on? Is that normal? I don't have any oil buildup in the middle of the car.
#55
Originally Posted by Eric - Plug Guy
Results are in:
Rear Main Seal replaced.
Measurements are shown here:
[image removed - measuremenst are 10.16, 10.02, 9.92, 10.15 clockwise from the top]
Are those radii? or are those diffs to the exact circle? 2 numbers are close 10.15 and 10.16, but the others (10.02, 9.92) are far off.
In any case, they replaced the seal. OK... what was wrong w/ it? Was just a bad seal (doubtful)? did they use a different type of seal? any reason the new seal will not start leaking at some point? my questions really lead to the cause; if the cause was not fixed, the problem was not fixed.
