Flat Tire - Plug repair? DC area
I came back from a trip to find the rear tire (Michelin Pilot Sport on 18" rims) had gone from 44lb to 4lb! I called Porsche roadside assistance, and they pumped it back up (at my request). Now it is down 10psi overnite.
One dealer recommended NTB for a plug repair - any advice against this? I am in the DC area.
Also if you have the tire off, check the wheel for cracks. After one blowout (due to lo pressure) at 75 and a tire rolling off the wheel (due to lo pressure) on a slow turn; I found I had a leak thru a crack in the wheel.
dont do it!!! When they plug it basically they take the existing hole, make it bigger and then plug it with a rubber cork of some sort. Have them patch it from the inside
A plug is a good way to die if you crank up the speed occassionally. A patch, however, will let you drive the car normally. I had a tire on the M3 patched a few years ago and never had a problem with it.
Originally Posted by winovin
How do they check for cracks? x-rays?
I was amazed that you really can't see low tire pressure, the side wall is so rigid.
It depends upon where the leak is. If it is the side wall, then even a patch will fail over time due to
flex. If on the tread part of the tire, an inside patch will work fine. FWIW, I have used the self vulcanizing plug kits from NAPA, Walmart etc. with great success and never had one fail. One need not make the hole bigger. That said, the steel wires, I am told "can" cut the plugs over time.
Not a good idea to track any plugged or patched tire....you'd only be looking for trouble. However, I also admit to doing that a number of years ago, uneventfully and multiple times until the Dunlop wore out. All of this before I was any wiser.
regards,
Steve
regards,
Steve
NTB found a screw about 1 inch from the sidewall, and told me it was too close to the edge to patch.
A Porsche dealer said they could plug it
Cost on both is comparable (around $30)
Advice/comments? From what I have seen/heard, patching is preferred, but is the location problematic?
Look for a local tire dealer that does both. Many of the small tire shops that also do auto repair may do both. Several in my area do. Or plug it yourself and bring it to the shop that will patch it. When the tire is removed, all they have to do is cut the plug flush and patch over it. Are these the orginal tires?
