Headliner vibration?
When you open your sunroof and drive (even at moderate speeds -4-60mph) does your headliner, behind the sunroof opening vibrate? You can easily see this in your rear view mirror.
Mine does. I think that rushing air is mostly trapped inside the headliner cavity w/ a slow exhaust through the back, causing this. Is this the norm? Is there a fix?
When my sunroof is open, it alwasy happens.
I understand now that it vibrates if it's missing a fastener or is not attached completely. I will have it checked.
LiveNupe, GoMo, post here if your dealer finds the problem.
