Leather Ignition Lock Rosette
One of the options on my 99 C2 cab is XJ4 which decodes as "Leather Ignition Lock Rosette". Does anyone know what this is? Also, I have several other codes beginning with X (XE9,XKC,XKH,XKN,XKS,XNW,XPC,XPX,XTK,X54,X66) that I cant decode with autopedia or kindel. Any help would be appreciated.
the ignition rosette is the oval shaped trim around the ign switch. Obviously it is leather covered. I bet the rest of the codes are other odd parts covered in leather. Those parts are usually in plastic, someone wanted more leather trim. It was a special order and maybe your interior has an odd color?
This site is good for decoding all the codes under the hood, at least it worked for me!!
http://www.kindel.com/Porsche/options.asp
