navigation value
navigation value
a fellow rennlist member is offering to sell his nav & changer from his 40th anniv. 911 (almost new). any thoughts on what this is worth? and what might it cost for me to add it to my 04 c4s?
many thanks.
sm
many thanks.
sm
Should be a simple job. It is a dealer upgrade to retrofit nav system. I would think all the wiring is simple plug & play. Maybe they add a different wiring adapter or something. All thats missing is the gps antenna module. It should be in the dealers labor cost book . Thats why you can simply call them and ask. I removed the whole bose system and replaced with completely different system. There wasnt anything too mysterious in there.
Yes, my dealer told me that the 03 and 04 radios have to be turned on by the dealer. (PS only radios in 03 and 04 are interchangable, you wouldnt be able to use them from previous years.) I dont know if its a code they will give away, or if they have to enter it with their computer, or if they would let you do it. Also you will need the inner bracket for the nav radio which is different from the regular radio bracket. Hopefully the guy would include that with the unit.
