Question - WHY Tiptronic Over 6 Speed Man ?
#31
Interesting to see how some manual shift owners look down upon tip owners as if tip owners do not know how to shift properly. I do prefer manuals and own nothing but mauals except SUVs but dont assume people buy tips/autos because they dont know how to drive a stick. Remeber that there is no clutch you have to manually enagage in f1 cars either.
#32
Registered User
#33
I am curious. We have a 6 speed manual 996. We also have a Mercedes ML with Mercedes version of the Tiptronic transmision. While it technically works, there seems to be a total lack of "feeling" when shifting the gears and a noticable amount of delay. While I know that it is very hard to compare the transmissions of a sports car and truck, I'd be interested in peoples opinions on the "feel" of the 996. To make it more clear, we had an auto 928 and often "shifted" the gears ourselves. While there was no clutch, there was still a connection when going from 2 to 3 for example. The Mercedes on the other hand feels completely electronic, a sensation that I'm not as fond of (for enjoyment... I'm sure it works 10 times better).
So, does the 996 tip feel overly "electronic", or is there still some sort of mechanical feel to the system?
Jeff
Jeff
#34
Having just gone from a manual gearbox to the tip gearbox in a 996 there are obviously changes in the "feel" of the car. Also going to a C4S , the car feels heavier but alot more solid then the Targa.
There is certainly some mechanical feel to the Tip transmission under hard or spirited driving but then there is also a smooth feel while just cruising to work in traffic. The shifting is smooth but not as lifeless as the ML we had years ago and "feels" better then the BMW system we had on our 540.
I look forward to tracking the car this Monday at Dunnville, a very tight circut, will be a good test of the system. I intend to get back into a 6speed for track days anyway, but it will be fun to throw the tip around.
#35
R.I.P.
Lifetime Member
Lifetime Member
Carbon is correct. No comparison between an ML and a 996 Tip. My Cab is a TipS and I enjoy not lifting when shifting in manual mode.. I like downshifting approaching a curve or stoplight. I always drive in manual mode and start off in 1st gear.
It is definitely different than std. but has it's own benefits.
Also the stats for a Tip and a manual are not that different if you check.
#36
Porsche's own performance figures show almost 10% less performance when using the TipS. That's a pretty substancial difference if you ask me.. That's like lowering your horsepwer from 330 to 300.
#37
"Porsche's own performance figures show almost 10% less performance when using the TipS." That's straight line performance. Put the two cars on the track and the difference, according to race car drivers like Hurley Haywood, is negligible. Tip's advantage on the track is that it's easier to keep the car stable. check some of the posts above on that.
#38
I prefer sticks over tips, but I do not look down on the tip. However, since my car has PSE, I cannot imagine having as much fun with a tip. I have noticed that I have changed my driving since installing the PSE just to hear that sweet, sweet sound. I have also, on occassion, used it in place of a blast of the horn. Porsche as musical instrument?
#39
I went with the TIP for the same reason that I bought a cab. Flexibility, so that I can drive the car every day, enjoying it for the situation that I happen to be in.
Sunny day in the mountains - top down, manual mode
Rainy day on the freeway, talking on the phone & drinking coffee - top up, auto mode
(and a whole lot of circumstances in between, that I can re-cofigure for in seconds).
Do I lose ultimate performance by having a cab or by having a TIP? Perhaps, but the overall package is still quite satisfying for any situation I find myself in.
I drove manual performance cars for many years. Do I miss "rowing the gears" ? Not really. Keeping my left foot still and my hands on the wheel is different, but not worse. If you ever dreamed of shifting while your right foot was planted, you ought to actually test drive a TIP and have a first hand experience before nay-saying. It's not for everyone, but I'm sold.
#40
PSE sounds just as good with a Tip...in Manual mode it's the same sweet sounds.
#41
i prefer a stick over tip - generally. however, there are times during stop-go traffic (especially on a hill) when i might prefer a tip. that said....my girlfriend and i keep tossing around the idea of getting a 996. in that case - despite my best efforts to teach her a stick - she'd be more comfortable with a tip. and since we'd both be driving it, i can handle a tip in the garage. i'd rather have a tip 996 than no 996 at all....unless i'm 'stuck' with my 951!!!!
#42
