Front ABS engaging
Pocket Sand
Originally Posted by tstanding
I also have this happen on a C2 with USA 030. I seems to require braking in a turn with less than perfect pavement. If the inside front wheel hits a bump, the ABS will engage on that wheel. I have found that if I complete my braking a little earlier it doesn't happen.
I just figured it was the car telling me that I was braking too late.
Tim
Tim
Kevin H.: Couldn't you just pull the fuse for ABS/TCS from the fusebox? (on a side note, how cool would it be to have an ABS on/off on ur center consol as a button right next to PSM and TCS)
