996 Forum 1999-2005
I tried to Dyno my car today...
Old 09-18-2004 | 03:38 AM
Itzkirb's Avatar
Itzkirb
Default I tried to Dyno my car today...
OK, so I tried to Dyno my Supercharged car today, but we had some problems. First off, has anyone with a Tiptronic dyno'd their car and if so how?
I brought it to the Dyno place, hooked it up and ran it. The results were terrible. It seems that with a Tiptronic there is a built in torque converter? Something was happening that did not allow my car to show it's full power. In fact the Dyno result came in lower than a stock C2 would have. I guess the car senses the front tires not moving and cuts some of the power for safety reasons?
I do not have PSM so that wasn't the issue. Does anyone know how to Dyno a Tip?
Old 09-18-2004 | 05:41 AM
nman413's Avatar
nman413
kirby, ask sharky. his car doesnt dyno either.
Old 09-18-2004 | 03:58 PM
Itzkirb's Avatar
Itzkirb
Jaunder
Yea, I already talked to Alex. Bummer...
Old 09-20-2004 | 04:01 AM
Itzkirb's Avatar
Itzkirb
This is from Loren at Renntech.org...
Here is an excerpt from a TT TSB on dynos:
If the vehicle is run on a two-wheel roller dynamometer, sufficient inner-cooling cannot be ensured. As a result, boost air temperatures reach excessive values. This will lead to loss of engine power and damage to the engine due to overheating.
The considerable amount of heat generated may damage the transmission. The significant amount of slip at the wheels caused by the high power output may lead to incorrect output measurements and damage the tires.
Note: Tire damage may not be immediately recognizable.
http://www.renntech.org/forums/index...topic=2894&hl=
Old 09-20-2004 | 04:20 PM
alain-964c2's Avatar
alain-964c2
Manual says never to dyno the car form similar reasons.
Old 09-20-2004 | 04:27 PM
Stevo'99's Avatar
Stevo'99
Kirby-
Todd has done many Tips and I'm sure he's dyno'd some. Did you try asking EVO?
Old 09-20-2004 | 04:44 PM
RJMDAD996's Avatar
RJMDAD996
After reading that mark up I would not try it, not worth it...
Quick Reply: I tried to Dyno my car today...
