Looking for a damaged cluster
Guys:
I have an odd request.
When I swapped my gauge faces last week my Speedo and Volt needles were inop on re-install. I pulled the little motors apart on the back of each one to look for the problem. I found that the small acutuator screw had popped off its support. I was able to fix the speedo but I nicked the inner coil on the volt gauge and it is caput.
SOOOOOOOO all I really need is the voltage gauge and I am off to the races. So does anyone have a damaged cluster I can disect? Or do you know where I might look for one?
Thanks gang
Thanks gang
