Oily spots on both driver and passenger side windows ??
Me again,
Does anyone else experience this ? I clean my windows and if I put them down a round oily spot appears in the upper corner of both windows
I have the exact same thing and I can't figure it out. I have tried cleaning the insides of the two strips holding the window and it didn't work. It's got to be something inside of the door. Anyway, both my doors are rattling pretty badly so I will get the dealer to fix both problems when they take apart the doors...
Each window has 2 regulator pads, and yours have gotten dirty and need to be replaced. I've had this issue on all 3 of the 996s I've owned (multiple times on 2 of them). Half the Boxster loaners I've driven also had the smears. Dealers keep these in stock and replace them under warranty.
Originally Posted by SYMA
Poursha,
They are oily, when you say dirty do you refer to dust build up ? if so then where the heck does the oil come from ? It is a very clear oil
I saw a Carrera GT at the dealer a while back, and it had a smear on the passenger window!!
Thanks for the info. I've got an oily streak on both windows and I'll have it looked at during my first service.
