996 Forum 1999-2005
Paint Chip Help/Advice Please!
Old Aug 5, 2004 | 08:01 AM
winovin's Avatar
winovin
Default Paint Chip Help/Advice Please!
Hi,
Yesterday I noticed a small 1/4 inch chip about 3 inches below the fuel filler (noticed it while gassing up). The car was dirty and it looked like someone had bumped something into the car because there was a slight smear forward of the chip.
The chip itself looked like only a thin surface layer of Arctic Silver paint had been scraped off - there was a duller silver/grey paint layer intact underneath the disturbed layer.
What are my options, and what is the preferred alternative? What should I NOT do?
Any advice appreciated, thanks in advance,
Wino
Old Aug 5, 2004 | 08:02 AM
winovin's Avatar
winovin
Also, I am in the DC area, so any recommended facility in the DC/VA/MD area would be appreciated.
Once the chip is repaired, how long before I can have the car washed and waxed?
Can a car detailer fix this? Should I take it to Porsche of Arlington?
Thanks again,
wino
Old Aug 5, 2004 | 10:07 AM
Chronos's Avatar
Chronos
I'm interested as I have a similar chip and dent where somone in an SUV hit my driver's side rear fender with a door (hit and run... thanks) and also live in the DC area.
I'd have to believe a Porsche dealership would be the most expensive option?
Old Aug 5, 2004 | 10:46 AM
Eric - Plug Guy's Avatar
Eric - Plug Guy
Basic Sponsor
Try Langka.com
I've not used it, but many Porsche folks have and swear by this product.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring 6sp
2009 997 Turbo Cab 6sp
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Old Aug 5, 2004 | 11:22 AM
winovin's Avatar
winovin
Thanks Eric - looks interesting, but I don't want to take any chances.
I thought chips can be buffed out? Or should it be touched up?
I am looking for a pro to take care of this!
Old Aug 5, 2004 | 12:25 PM
Poursha's Avatar
Poursha
Take it to high end detailing shop. If it's not too deep, they can color sand and buff it out.
Langka doesn't work well on arctic silver--it ends up removing the silver flakes, which leaves the repair darker than the original paint.
Old Aug 5, 2004 | 12:36 PM
Scouser's Avatar
Scouser
Actually I have found that Langka doesn't seem to work too well on any metalic painted surface. My zenthth blue 996, my wifes metalic black Alfa and my previous Gunmetal Silver Audi all have/had metalic paint and I found that this was always the case, it leaves the repair in a different shade to the original colour.
I have several chips, one or two are as as bad as you describe here. I think the only real way to deal with them is have them fixed up in the body shop.
Old Aug 5, 2004 | 11:04 PM
okbarnett's Avatar
okbarnett
The best you could do with the exception of painting the whole panel; Clean out a little with rubbing compound. Get origional paint (just the base coat color) or at least one of those touch up tubes from the dealer. Use small brush and dab a drop at the time of the origional paint in the chip. Dont get any outside the chip. Let each drop dry. Use compound and smooth off every coat. Hopefully you can build the chip up to the paint surface.
Old Aug 6, 2004 | 04:52 AM
Porsche Extremist's Avatar
Porsche Extremist
Best recommendation after fixing it is to install a 3M clear bra, saves the front bumper to make the install worth it.
