996 Forum 1999-2005
Single Click Starter
Old Jul 30, 2025 | 06:34 PM
Clockel's Avatar
Clockel
Originally Posted by DBJoe996
Just a thought, it could be a bad/weak cell in the battery so it doesn't make the complete circuit. Maybe try a new battery. If the battery is over 4 years old it's about time for a replacement anyway.
A fair thought as well. I have considered a battery as well just in case.
Old Jul 30, 2025 | 08:21 PM
Clockel's Avatar
Clockel
Well, that was a $413 (including starter and ignition switch) oversight. When you grab a cable and assume it is tight without actually checking nut torque, you become an idiot. I am you...
The ground strap was loose on the chassis side as I did not torque it a second time.
Thanks for the input guys. I also paid for a ton of research as I learned a bit about the additional issues with the ignition and I learned how to get rid of the clutch safety switch. Cheers.
Old Jul 30, 2025 | 11:51 PM
theprf's Avatar
theprf
Glad you got it sorted out.
