Dragging caliper
Not sure what all this talk about cleaning under the dust boot is for 20 + year old calipers. We are not talking about newer calipers on a race car.
'never time to do it right always time to do it twice' is what I use to tell the guys that worked for me when doing something half a$$ and getting call backs...
Do it right, its not hard. Take them apart, clean/blow out all the smegma you're sure to find inside 20 yo calipers. Use brake clean and compressed air. Install new seals and dust boots, bleed correctly and call it day.
Rebuilding them is not hard, or expensive. you don't have to paint them.
jmo
jmo
This is the way,..
High Temp Caliper Rebuild Kits For Brembo Calipers; Caliper Pistons
Ohio Clothing
www.ohioperformancesolutions.com
2007 C4S F77 Aerokit / 2004 E46 M3 / 2018 M3 comp
Ohio Clothing
allcool (08-04-2024)
One possibility that I have not seen mentioned in this thread is the that the metal shims behind the brake pads might be the culprit. The shims are adhered to the pads, and they help reduce brake squeal. However, sometimes the shims can seperate from the pad resulting in unusual pad friction on the rotor. It happened to my car. I even rebuilt the offending caliper before properly diagnosing the real problem. Simply removing the shims solved the problem. I too saw slightly higher brake temps on that wheel.
hardtailer (08-07-2024)
The squeaking is slighter now, but can still be heard when slow rolling near any side wall or row of cars.
No need to remove the caliper. Just remove the pads from the caliper and inspect the shims. Each pad should have a shim attached to it. However, a loose shim can create problems. If you do discover loose shims, simply discard them. They do do not affect braking performance.
