996 Forum 1999-2005
How to acknowledge warning light on dash
Old Jul 15, 2024 | 10:51 PM
43rdworld's Avatar
43rdworld
Default How to acknowledge warning light on dash
I've put in a new battery, horn going off (need to pull fuse) - all I need to do is get a pic of the odometer for the Porsche insurance. But I have a warning light telling me I have low brake fluid. Since the car is on the lift and in all sorts of pieces, I don't care -- the car isn't going anywhere, I know exactly why the fluid is low and I just need to get the image by Wednesday to renew insurance. All my searching tells all about the lights - nothing about how to simply say 'OK'. Thanks.
Old Jul 15, 2024 | 11:09 PM
wyowolf's Avatar
wyowolf
at least on mine the lower left stalk will acknowledge msgs and such and let you cycle through temps/ MPG etc. I believe pull backward
Old Jul 15, 2024 | 11:27 PM
De Jeeper's Avatar
De Jeeper
Btw its not the normal horn....its the alarm horn thats going off. Renove the plastic panel that covers the brake master cly and u will see the speaker by the brake rod. Just pull the the wire off.
If u have a 4 stalk car just pull the lower left stalk to clear the alert.
Old Jul 16, 2024 | 04:20 AM
parris's Avatar
parris
This
But I think that OK is pushing forward.
Old Jul 16, 2024 | 10:23 PM
43rdworld's Avatar
43rdworld
Thanks - I got it done tonight. I have a two stalk and when I turned the key this time, the message was gone. I did pull the horn fuse so may have been why the message disappeared. As with many things on this car, I don't know - but it made it much nicer in the garage and got the pic I needed. Thanks for all the help.
