Durametric and 1999 C2 Cabriolet
Top has had two separate malfunctions -after testing that flaps are working ok , reset clamshell potentiometer to 6.20 ohms and that microswitches' in latching mechanism are ok went to calibrate top .Nothing happened .The only commands I see on the durametric screen are reset faults and fault indicator in addition to the top calibration button .Some folk's have reported successfully recalibrating and having more command options ...my hypothesis is that the later revisions of the control module are more compatible with the durametric software .My question is if you successfully recalibrated your top what year vehicle and better yet what control module part number did you have.I would much prefer to upgrade the module if the durametric can calibrate it.
