996 Forum 1999-2005
1999, 996 carrera tiptronic transmission detail
Old 06-06-2024 | 04:44 PM
Gdjsk's Avatar
Gdjsk
Default 1999, 996 carrera tiptronic transmission detail
Hi guys,
I need to get some detail regarding a carrera 4 model 1999, this car was for sale in gulf country.
as carrera 4 is 4 wheel drive, during check we found that there are front drive shaft & front side all wheel drive as well, but the connecting shaft from front all wheel drive unit to transmission is missing.
I found a sticker on transmission but could not decode it.
I just want to confirm that this transmission is for the correct model( carrera 4), not a for carrera 2.
can someone explain please
Old 06-06-2024 | 04:57 PM
yelcab's Avatar
yelcab
Many people remove the drive shaft between the front of the gearbox and the differential at the front of the car to turn the c4 into a c2. If that were the case, you should be able to see the front of the gearbox to have connection points for a front drive shaft. If it is all closed up and just a clean nose, then the gearbox was for a C2 rear wheel drive/
Gdjsk (06-06-2024)
Old 06-06-2024 | 05:01 PM
Gdjsk's Avatar
Gdjsk
thankyou,
I noticed there was some connection point in front side of gearbox, although the splines were not clearly visible. Than it should be for carrera 4, as front all wheel drive & both drive shafts were there.
Thankyou
Quick Reply: 1999, 996 carrera tiptronic transmission detail
