How serious is this leak? 996.1
hardtailer (06-04-2024)
Looks like solenoid leak possibly? Easy enough to fix if it is.
Don't let an oil leak put you off, just be sure what it is first. Take a better picture above it.
https://rennlist.com/forums/996-foru...l#post19473610
Relevant cause he wants to know how big a deal the leak is, if AOS then tip v MT def makes a difference.
996love (06-05-2024)
The option sticker in his other thread showed tip, and he said this is same car but manual. Just confused.
This link is not related with this car but to help to identify the part that have the leak:
https://ibb.co/NV8KR1W
That is the chain tensioner. If that's leaking, then you would have to replace the aluminium crush washer.
But was there no oil higher up? That's where the AOS sits and it is a more likely source of oil weeping/leaks than that crush washer.
In reddit I have one user that is mentioning that the stock anti-aging coating from factory can look like an oil leak if the car still has relatively low miles. In this case the car have 44000 miles. Can it be a correct assumption?
Dude!! The only reason to go on Reddit is to troll redditors,,,,not for anything else! Get a PPI done!
