Is there any point in my trying to DIY AC not blowing cold?
#31
You really do need to fix the blend doors. When the foam's gone they are a piece of galvanized steel sheet that's about 30% holes. It's never going to be "cold" with that much hot air leaking in.
#32
Our cars take iirr 32 oz r134a. I'd try dumping the rest of that can in and see if your vent temps go down. Not sure what you meant by technical difficulties, assume you're having trouble getting the freon in. Make sure on your set up to fully turn in the needle valve to puncture the can fully, then back it out all the way. Charge at 1500-2000 rpm. Our cars have a long pipe run from the low side service port- to the compressor, so you can dump some liquid in for a few seconds at a time (invert can briefly a few times) might help to get all the dye in and charge faster with a small can...
The foam vent seal problem theprf explained is interesting, never thought of that. Without the compressor * on, but in hi fan/max cooling mode, does heat come out your vents, what temp do you get compared to ambeint..?
Per technical difficulties: Let's just say the EPA would not be impressed... and I'm glad I wore very heavy leather fire proof gloves while working with it....
I'll try to do the rest of the 12oz can with dye tomorrow. Any idea why when the passenger side fan kicks on (high) the low side pressure drops significatinly? And then goes back up when it turns off. Can't believe i gotta start trouble shooting the fans now. They used to kick on when I turned the car off, now they don't.
Yes vents might be an issue. Heater works 100% blasts hot air. And I just replaced water pump and full coolant flush from green to pink (trying to solve why it only took 5 gallons of coolant too, fun times here in home diy garage).
#33
So fully open the valve? I was reading it should only be done "slowly" but of course I don't know how slow or fast the valve lets the freon out.
Ok, after looking at your pic, not sure if you have the puncture type can that uses pointy needle type set up, and backing out the needle once can is punctured opens the can valve. or the self sealing can that can only use the flat nose needle that can only be used on the self sealing cans. Some of these self sealing epa can systems have funky valves that are fully open in the middle position, some in the full down position, iirr. I really don't like the new little can setups, but once understood they do work.
Bottom line, figure what setup you have and when the can valve is fully open. then use it fully open.
If you're having problems with the can/valve leaking and haven't figured out how to connect leak tight yet, don't use the freon leak dye cans as it will lightly stain anything it touches if its dripping down from a leaky can/valve/hose/etc....
Best to have a leak free charging setup before you use freon with leak dye in it... However, its a good idea for you to have some dye in there as we know you have a leak, just don't know where/how big it is and the dye will show that. Make sure to have the ac drain clear as the water/condensate that leaves puddles under you car will have dye in it if the evap is leaking...
Keep at it, you'll get it. Hopefully its a very small leak that took a long time to leak down. Or not, and you easily see the dye and change out the leaky part.
As for the vent door foam problem, wasn't asking you if your heater works. Was trying to figure a way to see how much hot air they were leaking in the cabin on full cooling mode. Hence me asking you to turn ac on max cool fan and lowest temp, then turn off the compressor * button on the control panel. Then measure vent temperature and compare it with outside ambient temps to see how much heat was being introduced by the missing foam seal. Let it run like this for a few minutes with doors windows open before noting temps.
jmo....
#34
No idea of the condition of my 996.1 & 996.2 vent door foam seals as I've never had problems or foam blowing around. But my top is down most of the time so that might blow the foam out of my car before I see it..? But both cars ac works great with mid 40° vent temps when its hot out...
So, if I understand you correctly, the vent doors have holes (30%of the doors surface area..?) all thru them like Swiss cheese and the foam covers these holes blocking air from passing thru the holes..? Any diagrams/pics of the doors we're taking about. What should i search for to see this..?
#35
This is what the blend door looks like. The white showing through the holes is cardboard that I glued on to the opposite side. It's easy to see why the blend door does not do much once the foam is gone.
allcool (05-01-2024)
#36
Is there a good test to see if the foam is gone.?
#37
I suppose an endoscope would do the job. I think the temperature blend door can be easily seen from the access hole in the frunk used to change the heater core.
allcool (05-02-2024)
#38
1. I think the connection is tight, yeh don't want to be staining everything connecting the can. The gauge is a needle valve, god I just assumed the can was the same. Says is a "self-sealing can", though I'd dare not disconnect it considering the first time I connected it I froze my leather glove solid
2. Will connect it all, and turn on car. High AC (it's bugging me the front right fan isn't turning on with AC)
3. Open valve fully, rev engine to 1500ish and keep checking the PSI.
4. Cross fingers.
5. Measure vent temp with temp thermo-pen gauge. Have a infrared gun too.
Questions:
1. Is it possible to over fill the compressor? is there a symptom to look out for?
2. Why would the low side pressure drop significantly when the fan speed goes from low (
(NOTE found I have a missing relay which is why Fan 2 Low was not engaging. Popped in the high one to test, now both fans turn on low--- sheeeesh!)
Also a tad concerned that the high fans only turn on for a few seconds, even though coolant temp (via OBD) were getting up to 210F. I DID just change coolant and put in a low-temp LN thermostat. And I had the engine bay open the entire time, and read the engine bay temp can be used to trigger fan speeds.
So many questions!
#39
Here is a good chart on what a healthy A/C system reading should be.
#40
I must have checked fans at high at some point and assumed they worked. I did find low speed was not working on one side - and now like an idiot, found I'm missing the relay entirely for that fan+speed. So that's one less thing to troubleshoot!
#41
When the fans shift to high speed there is much more air over the condensers, which cools off the refrigerant more, so the pressures go down. Then when the pressure goes down the fans shift back to low speed, the refrigerant gets hotter, the pressures increase, and the fans shift back to high speed.
If you are in traffic on a hot day you should hear every car doing this.
But seriously, you really ought to get a real refrigerant gauge set. High side pressure tells the story. Sometimes you can rent them from Autozone. You can get a nice set from Amazon for about $60.
www.amazon.com/dp/B088RLQKR6
#42
Your valve and can are not compatible! I experienced it myself not knowing that self-sealing cans had appeared on the market and trying exactly what you did.
Your only option is to replace the valve with one for self-sealing cans. The center pin in that kind of valve moves down onto the valve in the can and opens it and the r134a then flows around it into the hose. It must stay turned down for as long as the r134a is to flow. Once done, turn the **** in order to retreat the center pin and the can will be sealed again. After that you can safely unscrew the whole valve from the can.
#43
Found this thread when checking your profile to see what 996 you drive as I replied to 'hot engine:..'
The valve on the gauge I bough, has a needle that when turned all the way blocks the flow (in order to pierce the foil). But I guess I see your point, that if I turn it all the way OUT, then the can would seal itself.
I just searched the answers section on the product in Amazon for "self" and low and behold the seller says "no" it doesn't work with self-sealing cans. Some reviews said it work, but... sigh. I don't usually return items to amazon that I legit used, but I am going to return this one.
Thank you for the note!
hardtailer (05-09-2024)
#44
[QUOTE=Ben8jam;19428924
[/QUOTE]
Like I said above, they both use a needle. But, The needles are different.
The puncture cans have a pointy needle, the self seal cans use a flat nose needle.
Look at the the end of the needle, if its sharp pointy, its for a puncture can. If it has a flat nose, its for self seal cans.
[/QUOTE]
