996/986/987 - Specific Camera Cellphone GoPro Radar Detector Mount RoadSpy RS2
Premium Sponsor
Hi All! Very happy to be a new vendor on Rennlist! I started out with my first Porsche (914) almost 40 years ago and have a passion for all things Porsche. Please reach out with any questions and I'm looking forward to meeting new friends and helping capture some epic memories. Below, please find the details of our RS2 for your 996/986/987:
RoadSpy R2 is custom-designed for your Porsche’s rear view mirror base. RS2 offers the most clutter-free & secure mount for your action cameras, compatible with GoPro cameras, other cameras & cellphones using the included adapters.
- Designed to fit 996986 997 PORSCHE 911 BOXSTER CAYMAN. Includes phone mount and 1/4" camera adapter.
- Conforms to interior rear view mirror base. No permanent modification to your Porsche.
- Rock-Solid mount designed to fit GoPro cameras, other cameras, cellphones or radar detectors.
- Mounted up high and on car's centerline, your camera will capture the best possible view.
- Designed in Florida, USA. Manufactured from quality automotive grade materials.
- Super easy 2-minute installation.
- Easily removed. Quick attach/detach of your camera.
- NO SUCTION CUP FAILS! The Only Mount You Need.
- https://roadspy.com/RoadSpy-SUPERMOUNT-RS2_p_13.html (use RL member discount code RL2024 for 10% off).
Last edited by RoadSpy; 05-20-2024 at 02:18 PM. Reason: Correction of model number
Premium Sponsor
https://www.ebay.com/itm/125619379875?chn=ps&mkevt=1&mkcid=28&srsltid=AfmBOopGKeoYyeWkwvqmPxo5TlQ Ks2en2dAeob6In0lm4YpfJMKbVrm67Z0&com_cvv=8fb3d522dc163aeadb66e08cd7450cb bdddc64c6cf2e8891f6d48747c6d56d2c
Only need the bottom portion of this one (may need a 1" riser as well)
https://www.amazon.com/LycoGear-Detector-Connect-Adhesive-Detectors/dp/B08XYC5ZX3/ref=sr_1_13?crid=26UNQ3R5VSYIB&dib=eyJ2IjoiMSJ9.eIc5KKOU2uiGXPmP8sGZmpEc P0p8cgwQwq6oonLPWjv3gHN8WiQN5s26un1M2zWVFpP2A-mPU-ReQtFl7RVOeqlbtH-gfZfe8TyAUksK9jVjD3_44oQAfCr1iQqDUYvBMY5R-6zOa7c1VmtfYxTqFCj1bqgJcjHVJyLbbakX8e6N5TNX86Mrf0hmP9rR0CyUg8iTKwa2FyyNM BI-XN8yBq8vtJq53u61DQ-B6of9bgA.EjyT12W-9HEi1N3FdRsEVm-rh8BstNpGcPXM9Lcg1u0&dib_tag=se&keywords=uniden+gopro&qid=1709814945&spr efix=uniden+gopro%2Caps%2C102&sr=8-13
Premium Sponsor
Premium Sponsor
Use the bottom piece only. Use a 1" riser if radar detector needs to drop down to clear your mirror.:
Passport Radar Detectors 9500ix, 9500i, 9500i, 8500, X50 BLUE RED, 7500, 7500S, 6800, STI, C65 SOLO S2, SOLO S3, SOLO S4, SC 55, S75">
Passport Radar Detectors 9500ix, 9500i, 9500i, 8500, X50 BLUE RED, 7500, 7500S, 6800, STI, C65 SOLO S2, SOLO S3, SOLO S4, SC 55, S75" /> Passport Radar Detectors 9500ix, 9500i, 9500i, 8500, X50 BLUE RED, 7500, 7500S, 6800, STI, C65 SOLO S2, SOLO S3, SOLO S4, SC 55, S75">Passport Radar Detectors 9500ix, 9500i, 9500i, 8500, X50 BLUE RED, 7500, 7500S, 6800, STI, C65 SOLO S2, SOLO S3, SOLO S4, SC 55, S75
![<span style=](https://rennlist.com/forums/images/misc/amazon_icon.gif)
Escort Pasport MAX, MAX2 MAX II 2 Older MAX360 (2015-2019) Radar Detector (METAL Slide in Plate connection only NOT FOR MAX360C MAGNETIC cradle radar)">
Escort Pasport MAX, MAX2 MAX II 2 Older MAX360 (2015-2019) Radar Detector (METAL Slide in Plate connection only NOT FOR MAX360C MAGNETIC cradle radar)" /> Escort Pasport MAX, MAX2 MAX II 2 Older MAX360 (2015-2019) Radar Detector (METAL Slide in Plate connection only NOT FOR MAX360C MAGNETIC cradle radar)">Escort Pasport MAX, MAX2 MAX II 2 Older MAX360 (2015-2019) Radar Detector (METAL Slide in Plate connection only NOT FOR MAX360C MAGNETIC cradle radar)
Let me know if you have another brand/model, I can design one for you.
F. Thumb (03-11-2024)
Looks good, I want to order, but would like to confirm something: it looks like the bottom end of the unit is at a similar height to the base of the rear view mirror. Just want to confirm that a radar detector would actually be able to fit, and not hit the mirror.
I have a Uniden so would likely need to purchase the adaptor that you linked above. However this adaptor looks a lot different to the sample radar detector pic that you have (which seems to "drop down" a lot more)
Premium Sponsor
AngeloGTS (03-08-2024)
I’m looking at the RS2 but my car has a rain sensor, would I need a RS1 or RS2?
Premium Sponsor
Thanks for the question because I realize I need to add some more information to our fit chart. The RS2 won't fit on any rear view mirror base from the mid-2000s that has the rain sensor/auto dimming, will only fit the manual dimming mirrors with the little tab. The model you'll need is the upcoming RS4 which is for all 997's and late 996's that had the auto rain/dim function. RS4 is due out this Fall. Is your 996 MY05?
Premium Sponsor
UUUUgh I got one of these and somehow dropped 2 of the little screws while installing. I have NO IDEA where they went! Used a flashlight and magnet to try and locate them. Just a heads up use a towel or tray just in case you drop one (or 2) to catch them if they fall. Must of gotten into the vents or something...
