Brake Return Pump
Brake Return Pump
Hello Porche Enthusiasts
I have on 02 C4S
the dash light are on for PSM and ABS
Checked with computer and it spit back
Brake return Pump YIKES
Anyway a used on is about 2000
Can anyone give me some feedback as to which ones may fit and actually function on my car?
I found an 04 turbo with the same part number
99635575563
might this work ? part number is same but stamped number at bottom is different.
I have on 02 C4S
99635575563
It's usually the transistor that controls the return pump that blows up.
Find a place that can fix Bosch 5.7 ABS (google). The black electronics part can be removed from the ABS unit. Send them the electronics part, tell them "return pump", and they can fix it.
The following 3 users liked this post by theprf:
Thank U
My mechanic never mentioned this to me
I will check out what you suggested
