I picked up a 01 996 and the guy never cleaned the inside of the rims and now I'm trying to get them cleaned. I used the regular washing soap and that took care of some of the dirt but what remains almost looks like stains. Any suggestions on removing that?
I used Chemical Guys iron remover, let it soak as directed, scrubbed the barrels, then used Meguairs All Wheel Cleaner. Repeated until the desired results are achieved.
I’d probably start with an iron remover but I use these two together:
The one thing about Iron remover is to make sure you get all of it off. Usually use a separate bottle or pump sprayer. I use P&S for their Bead Maker as well, for best results remove the wheel and work off the car as some of advised.
