996 Forum 1999-2005
Function First “just right” shifter
Old Aug 12, 2024 | 10:18 AM
FlattestSix's Avatar
FlattestSix
Originally Posted by imtherealgusbus
when you say that it’s not a night and day improvement, would you say all the slop is that comes with the factory bushings are removed? Or do ya mean that there is still some play with the function first kit
I think it’s a question of how much slop you have before you do the upgrade. The biggest change I noticed was the solid feel I got when shifting into first, as opposed to with the stock setup where it felt like I was in muddy water hunting for the gear.
The others have gotten better as well. I think for me, I partly assumed that it would be this almost gun-like feel, precise metallic sound, etc. And it’s not that. But it is better. And I have more piece of mind knowing that the components are aluminum and also simply the fact that I put it together myself and now know exactly what the bits inside are.
In a perfect world, I’d love a shorter throw from 1st to 2nd.
Hope that helps
Old Aug 12, 2024 | 10:34 AM
wdb's Avatar
wdb
I have a stock 996 plastic shift lever unit + Shift Right bits installed. It took all of the play out of that assembly. It made the shifting more precise and predictable. I still don't like how it shifts. I've been spoiled I guess, by having had several cars with truly wonderful shifter action.
Before:
After:
