2002 Coolant line kit
My ‘02 C2 is leaking coolant from a couple of connectors and obviously everything needs to be replaced (overflow tank already replaced).
is there anything like this for a 996? I can’t seem to find anything. Appreciate any help!
https://www.fcpeuro.com/products/por...kt#description
FCP kits are not discounted, they allow you to add a group of parts at regular price to your cart with one click.
While I don't understand how its obvious that everything needs to be replaced, do you believe the hose is leaking or that the connection is not good? I don't hear al lot of reports of hose failure.
This one I did witness at the track having a failure.
https://www.fcpeuro.com/products/por...saAj1jEALw_wcB
I had the same hose go that was mentioned by hbdunn. It blew out on the road. and ended my day. It is the only one I've lost so far. I have replaced only one other on a prophylactic basis: 996-106-223-52 and the connector to it: 996-106-226. That last one, the best option is the R&S. The URO and Porsche stock are not as well designed.
