AOS Change - Dumb Questions
Hi, thank you very much in advance.
The 1st of many:
Is there a trick to get the connectors pictured off, the book says “squeeze to disconnect” well the bitch bolt was easier, after trying for half an hour I’ve given up !
The 1st of many:
Here is a picture of the tool. You don't have to use one but this gives you an idea of how to release it.
Push in squeeze then pull off.
https://lnengineering.com/notta-wren...86-models.html
I started just the back bolt for the driver intake a few threads, but didn’t tighten. Next I installed the rear plenum in the passenger side intake with the driver side intake angled outward. I then rotated the driver intake into place and started all the bolts, but didn’t tighten. Then I just forced the front plenum on before tightening the intake. Make sure to push the rubber rings on plenum as far as you can, then center them before tightening the clamps.
