996 Forum 1999-2005
Timing Tool Kit Selection Help
Old 09-12-2023 | 05:54 PM
hbdunn's Avatar
hbdunn
Originally Posted by sabres32
Jandackson, Which kit do you have that will do both types "VarioCam and VarioCam+ " cars? if I'm spending money on tools I'd like to make sure they support numerous versions or models if possible.
They are essentially two different kits. The three chain engines don't need the hold downs and use a tool to rotate the cam from the chain side. That makes them less expensive.
https://www.ebay.com/itm/15529433299...UaAhEhEALw_wcB
Yelcab prefers to lock the cam on a 5 chain engine with the tool from this kit rather than use the tool that allows you to rotate it into position.
Using the 9612 tool
Old 09-13-2023 | 08:52 AM
sabres32's Avatar
sabres32
hbdunn, Thanks for the clarification on the two different tools.
Old 09-14-2023 | 03:27 PM
jandackson's Avatar
jandackson
My bad as I forgot that I had to buy a separate kit for the cam lock tools. Got it on eBay and it worked well.
amargari (09-15-2023)
Old 09-14-2023 | 04:34 PM
98-996's Avatar
98-996
Ebay kit worked just fine. used it on my vario-cam actuator replacment.
