996 Forum 1999-2005
European Parts Solution IMS install tool
Old 08-30-2023 | 02:39 AM
Carlo D's Avatar
Carlo D
Default European Parts Solution IMS install tool
Any one have the EPS IMS installation tool I can borrow? If so will this tool also remove the LN single row retrofit bearing currently in?
Old 08-31-2023 | 10:38 AM
Charles Navarro's Avatar
Charles Navarro
Their tool will not remove any LN bearing.
If you want to replace it with a roller bearing, we do offer the RND RS Roller IMS Bearing with free tool rental (which includes the adapter to pull the LN bearing as well as the optional RMS tool as well):
https://lnengineering.com/products/t...ofit-kits.html
wdb (09-02-2023)
Old 09-01-2023 | 08:46 AM
Carlo D's Avatar
Carlo D
Charles
I have a 2004 c4s with the single row retrofit that is overdue for replacement. I was planning on replacing it with the single row Pro but I’ve noticed the price had gone up to $900+ even on the ebay store. If I am remembering correctly they were $600+. I may be remembering wrong. RND is for ‘97-01 correct? With that said the EPS seemed more of an affordable option.
Old 09-01-2023 | 10:31 AM
Charles Navarro
Charles
The RND cylindrical roller bearing kit is available for both models with single and dual row bearings.
Sales volume has increased on these kits and that has allowed us to buy bearings in higher quantiles, so that let us drop the price significantly. As long as that holds up, we should be able to continue to offer them at the new lower price.
wdb (09-02-2023)
Old 09-01-2023 | 03:14 PM
Carlo D's Avatar
Carlo D
oh right!
The RND was developed for SSF auto parts in single and double row.
I just got confused because of the Pro and then the Solution. So many to choose from.
and I Only need to select “IMS Retrofit + RMS tool” kit $400 deposit correct to complete the job? with that I’ll be able to remove the old retrofit IMS?
do I need the cam shaft plug and tensioner seal set?
Old 09-01-2023 | 04:42 PM
BRS-LN's Avatar
BRS-LN
Platinum Sponsor
Do I need the cam shaft plug and tensioner seal set?
Yes, those will need to be replaced when removed.
LN/BRS/FSI Customer Support
https://flat6innovations.com/
Old 09-01-2023 | 10:56 PM
Carlo D's Avatar
Carlo D
Thanks!
Charles had mentioned military veteran discount before. Can I get this by calling in the order only or through website?
Quick Reply: European Parts Solution IMS install tool
