Is PCCM+ worth it?
Thanks for the mentions guys! More info on our BTR option: https://rennkit.com/product-info/blu...-retrofit-kit/
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
Rennkit
http://rennkit.com/
- Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
- Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
- AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
Hi Bergs - sorry, didn't see this earlier. It's actually even cheaper now.
If all you want to do is charge your phone and listen to music, I have been really pleased with this .
Bellissimo (08-31-2023)
Same
I had that exact same BT unit before i went with Rennkit, it couldn't do phonecalls, and did not provide a USB function for charging and the music quality had a buzzing. Whereas the rennkit was able to do both.
I also had bought a cigarette lighter with a USB to charge my phone and it was not a good solution it looked clunky, and with the cigarette lighter being a european spec socket the adapter kept falling out or coming loose every 20 minutes of driving, i was looking for a better look and less cables so mine ended up looking like this... as i found a better USB adapter that i incorporated into the rennkit that replaced the factory cigarette socket hole exactly...
RennKit-Dave (08-31-2023)
