996 Forum 1999-2005
intermitent Ticking right side engine
Old 07-11-2023 | 01:15 PM
Faustino's Avatar
Faustino
4th Gear
Default intermitent Ticking right side engine
Hi friends, my porsche 996 have a ticking in the right side of the engine, this noise is in ralenti, with more rpm the ticking dissapear, I changed the oil presure release valve and the problem persist.
I attacht a video with the sound
Thanks for you help
Old 07-12-2023 | 01:29 PM
damage98MO's Avatar
damage98MO
Thanks for you help
(Edit) Disregard the below, looks like there another thread.
​​​@Faustino I think you might not be getting answers simply because you'll need to do diagnosis in detail. You can use a stethoscope thing to identify exactly where the noise is coming from. It could be water pump, it could be a lifter, there's just not easy answer I'm afraid. I will say that when I got my 996 1 I had a slight ticking from the passenger side as well but I changed the oil and at the same time added some ceratec, the problem went away. I've no idea how that the extra additive would help, it may have just been the oil change. To say an additive will help an engine is simplistic and optimistic I'm afraid.
Heres a search they might help you, a Google search for 'rennlist.com 996 ticking right side'. Good luck with your diagnosis. Your sound file didn't get uploaded to your post fyi.
I hope this helps!
Old 07-13-2023 | 01:11 PM
Faustino's Avatar
Faustino
4th Gear
Hi friends, thanks for all your help, bore scoring is the reazon of the sound.
Now we go to make the change of this parts, when finish with this I will give news about results.
Old 07-13-2023 | 05:42 PM
MyFavorite996's Avatar
MyFavorite996
Sorry … that’s unfortunate news, but I suspected that. Please let us know what the mechanic finds as they do the rebuild.
Where are you located?
Quick Reply: intermitent Ticking right side engine
