Selling My 1999 C4 Cabriolet
Due to an unfortunate confluence of events, I will be selling my 996. '
I simply do not have the time to properly care for the car. Not having a garage exacerbates the problem. It's time to pass the car along.
I'm essentially the 2nd owner, 2 brothers from CT bought the car new in 1999, and have all service records from new plus the window sticker. The car now has ~43k miles
I've addressed a number of issues and I've know of a couple that still need to be dealt with:
I would like to get $35k. Do you think this is reasonable?
John
- Things that have been addressed:
- replace brake booster, brake master cylinder, brake light switch, coolant expansion tank
- new rotors, pads, wear sensors
- FSI Stage I
- 3.4l to 3.6l
- CP pistons
- dynamic race-level balancing
- high performance ignition coils
- clutch, pressure plate, pilot bearing
- water pump
- IMS Solution
- UAOS (working with Skip on warning light issue)
- new engine mounts, transmission mount, engine oil level sensor, and clutch slave cylinder
- new front seat belt buckles (ABS light)
- Antigravity model AG-H6-40-RS 1500 CCA
- New Summer tires, winter tires have 3 seasons on them
- Remaining issues:
- 4-wheel alignment needed
- HVAC Foam
- bump stops disintegrating
- refresh suspension
John
John,
Looks like you have addressed all the issues, so $35K seems fair. We all have the damn foam problem. Post some pictures. Are you a CVR PCA member? We have a coffee run coming up July 8.
Theo
Theo
blacksquid (06-27-2023)
Yes, with stand and cover
and the following:
- Winter tires mounted on staggered turbo look wheels
- Durametric
- New California Car cover SuperWeave cover
- New headlight seals
- bits and bobs
From all the work you've had done, 35k seems like a steal. Is the body/interior in good shape..?
Why sell a sorted out 996 like you've got..? Very possibly car will be worth lots more in the not so distance future with the FSI upgraded engine.
jmho
jmho
