996 Forum 1999-2005
jacking up the 996: front
Old May 19, 2004 | 02:05 AM
penguinking's Avatar
penguinking
Default jacking up the 996: front
i searched and can only find threads about jacking up the rear, but is there a way to jack up the front of the car?
like if i drove the front wheels up on wood blocks, i could slide a jack underneath and jack the front up so i wouldnt have to run around and jack up each side individually.
thanks
Robert
Old May 19, 2004 | 09:30 AM
ZBlue996Kam's Avatar
ZBlue996Kam
Robert:
You could jack one side of the front high enough that the other side will leave the ground and put a jack stand underneath it.
Kam
Old May 19, 2004 | 05:12 PM
dgray996's Avatar
dgray996
I usually put a jack-stand under the front control arm, which is the same process I performed on my 993 for several years. It seems to work fine with no damage. If anyone disagrees, let me know... thanks.
Old May 19, 2004 | 05:35 PM
Gretch's Avatar
Gretch
Range Master
Pepsie Lite
You gotta jack each side seperately, there is no "center position" (like there is in the back of the car), where you can lift both sides of the car at the same time. I use two jacks.
Old May 19, 2004 | 05:49 PM
Tool Pants's Avatar
Tool Pants
Like this.
Old May 19, 2004 | 05:53 PM
Gretch's Avatar
Gretch
Range Master
Pepsie Lite
Originally posted by Tool Pants
[B]Like this.
Yeah, except I use jack stands, so as to not crush my mellon..........
Old May 19, 2004 | 06:23 PM
Tool Pants's Avatar
Tool Pants
Good advise. Never trust a jack if you are going to put any body part under a car. I will also sometimes also put a wheel that has been removed under the car since if all else fails the wheel is larger than my chest.
There is a jack stand in my picture but it is hard to see since the floor jack is in the way. I put it there on Alex's turbo. I also leave the jack in place even if the car is on stands and that is why you cannot see the stand very well in the pic as it blocked by the floor jack.
Old May 19, 2004 | 07:21 PM
Scouser's Avatar
Scouser
Here is what I do:
I drive my car up a set of Rhino ramps. If I have to take the wheel off I can easily jack up the car from there and remove the ramp.
low profile Rhino ramps: The dogs dangly bits for getting under your low down porker
