996 Forum 1999-2005
LSD retrofit
Old May 15, 2004 | 01:53 PM
stanmo's Avatar
stanmo
Default LSD retrofit
Hello,
With a manual transmission 3.6L Carrera, is it possible to retrofit the factory option (220) LSD? Has anyone tried it before and was the installation difficult? Can you actually order the parts from Porsche for the retrofit? Do I need to reconfigure PSM? Thanks very much for your input.
Old May 15, 2004 | 03:44 PM
jetskied's Avatar
jetskied
To put a LSD in you have to have the tranny taken all apart. That will be pretty expensive. My guess you will be in it $4k or more. I say a better solution would be to find a tranny with a LSD and swap it, then sell your old one. I'm not sure about the PSM, call Andial they probably have more answers to your questions.
Old May 15, 2004 | 07:31 PM
stanmo's Avatar
stanmo
Thanks very much for the information!
Old May 16, 2004 | 10:54 AM
wwest's Avatar
wwest
STOP!
You probably already have a "virtual" (PSM/Trac, ect.) LSD. It is entirely possible that if you put a mechanical one in it will NEVER be used.
Old May 17, 2004 | 10:26 AM
JimB's Avatar
JimB
Stanmo,
I'm not sure I would agree with either of the two previous posts. Porsche is already using LSD with PSM so it can be done and installing an LSD really isn't a big deal. Pulling the trany and opening it up really doesn't take that long. I would never even consider buying a used one. It will be expensive though. I'm not sure what the factory LSD costs but a good aftermarket will be in the $2k range and you should figure on a day of labor.
Good luck,
Jim
Old May 17, 2004 | 10:28 AM
stanmo's Avatar
stanmo
I will look into this issue and if I have any updates, I will let the board know. Thanks.
Old May 17, 2004 | 11:56 AM
Steve in FL's Avatar
Steve in FL
JimB: If you look at the lockup ratios of the LSD in the 40th Anniversary 911 they're pretty low. Speculation is that's a limitation of making the LSD work with PSM.
Old May 17, 2004 | 12:25 PM
wwest's Avatar
wwest
Hey, if I had the software sources for PSM I could disable any or all portions of its operation.
