996 Forum 1999-2005
7mm spacers rear
Old 03-06-2023 | 12:15 PM
glims's Avatar
glims
Default 7mm spacers rear
Hi,
I have a 996.2 C4 with 265/35-18 (10Jx18) rear wheels.
Does anyone know if 7mm spacers will cause the wheels to touch the wheel arch?
Old 03-06-2023 | 01:42 PM
AndrewK996's Avatar
AndrewK996
Are they stock wheels? If so 7mm, and up to 15mm is fine
Old 03-06-2023 | 02:02 PM
glims's Avatar
glims
No, this is replica 997 turbo rims.
Old 03-06-2023 | 06:48 PM
JTT's Avatar
JTT
You should have no issue with 7mm. Many run 15mm on stock ET60.
glims (03-06-2023)
Old 03-07-2023 | 10:03 PM
Falcon911's Avatar
Falcon911
Stock 10x18" wheels are ET65. You would already be +15mm with the 10x18" ET50 wheels so the 7mm spacers could cause some interference. The narrow 265 tires will help some but if you find too much poke with the spacers you can just not use the spacers, no?
glims (03-09-2023)
Quick Reply: 7mm spacers rear
