C4S Decklid on C2
C4S Decklid on C2
I have a '99 C2 and am wondering if the C4s decklid (with the reflectors) are interchangeable with my existing decklid... Specifically, if the size/dimensions/bolt patterns are the same. I've seen a couple of threads on this but haven't found a concrete answer...
thanks in advance for your inputs.
A C4S decklid will not fit on a normal narrow body. There is a company that sells the reflective strip tho...think its cargraphic
found it here:
http://www.stuttgartperformance.com/...5&cat=&catstr=
But you could probably contact Cargraphic directly..
found it here:
thanks!
I've seen that cargraphic strip and some have said it looks like a cheap add-on (which it is...)
Does the reflector decklid only exist on the C4S? or on some C4 as well? What 996 models are considered "narrow" vs. "wide"?
Thanks for any answers!
