CTEK MXS 5 Direct Connection
Apologies if this has been answered elsewhere but a ton of googling didn't turn up anything
I just got a CTEK MXS 5 to charge my 996's battery. At the moment its charging using crocodile clips with +ve on the battery terminal and -ve to ground (as per advice i'd seen on a number of posts).
What i'm not sure of is if i swap to use the direct connection eyelets, do they both go on the terminals rather than -ve on the ground? If so why?
Thanks very much,
Martin
Thanks very much,
Martin
