996.1 Aerokit Install TSB
Does anyone have the installation instructions for the Aerokit? Specifically need the side skirts installation. The front bumper and deck lid seem straight forward enough.
thanks!!
thanks!!
colorway (01-03-2023)
Thank you both!! Exactly what I needed
I opted to NOT use the self tapping screws to attach the strip to the sill as corrosion is bond to happen with them.
Instead I attached them using
3M™ Acrylic Foam Tape PX5005DT, Dark Gray, 0.5 mm
For the upper edge I didn't use the K2 adhesive that's mentioned but 3M™ Acrylic Plus Tape PT1100, Dark Gray, 1.14 mm
I peeled the backing off for an inch or so at the forward end of the sill cover and had it pointed vertically upwards. After having pushed the sill cover into the ledge I pulled the peeled-off backing upwards and rearward whilst pressing the cover hard against the sill right where the backing had just been removed.
This is the method for the 996.2 sill cover that does away with the metal strip/ledge altogether.
Spoiler
The following 2 users liked this post by hardtailer:
colorway (01-03-2023),
TexSquirrel (01-03-2023)
Need help
i need instructions as well but for the gt trim that assemble into the rear bumper, I got a set but without instructions or template to drill the holes, thanks much!
