996 Forum 1999-2005
295/30R19 on narrow body 996?
Old 12-20-2022 | 05:21 AM
tristan_od's Avatar
tristan_od
Default 295/30R19 on narrow body 996?
Does anyone know if the following would fit a narrow body (C2) 996?
“Porsche 911 997 C4 & C4S Carrera S II wheels and winter tyres (full tread / as new). Michelin Pilot Alpin PA4 295/30R19 and 235/35R19 DOTs are 2620 and 2820”
There a good deal on a set on Facebook locally.
Old 12-20-2022 | 08:39 AM
EVOMMM's Avatar
EVOMMM
295/30/19 will fit but the et of the wheels is the question
I have a few sets of 19s with 295 on the tire fit is good but my pics show the car very lowered second pic is GT3 R ride height
Old 12-20-2022 | 08:52 AM
EVOMMM's Avatar
EVOMMM
tristan_od's Avatar
tristan_od
Sorry for the follow up newbie question, but what do you mean by "the et of the wheels"?
I wouldn't be lowering mine, so if they fit on your lowered car I'm hopeful about mine!
Old 12-20-2022 | 10:46 AM
De Jeeper's Avatar
De Jeeper
The et is the distance the outside edge of the rim sits in relation to the wheel flange. The number should be cast into the back of the rim or if they r oem it can be looked up.
U can compare 996 factory sizes with these using on-line calculators.
https://tiresize.com/wheel-offset-calculator/
Old 12-20-2022 | 11:36 AM
TexSquirrel's Avatar
TexSquirrel
ET means Einpress Tiefe, which is German for Offset.
Old 12-20-2022 | 12:27 PM
hatchetf15's Avatar
hatchetf15
Und Eichhörnchen ist Deutsch für “squirrel”. Get some! Wide body ET wheels have more rim behind (after) the hub, so the face of the wheel will be more concealed under the wheel arch and the inner portion may contact body and suspension without proper spacing. A visual is worth 1,000 words. Use a wheel/tire size calculator to see what those tire and wheel numbers look like.
Old 12-20-2022 | 12:33 PM
Otto Bonn's Avatar
Otto Bonn
I have to give you guys credit for being genuinely helpful with this question... And for the short lesson in german.
Old 12-20-2022 | 01:29 PM
Khodey's Avatar
Khodey
Awesome thank you for this!
Old 12-20-2022 | 09:08 PM
JohnCA58's Avatar
JohnCA58
I am running 295/30/19 tires on 19x11 wheels and 58 offset on lowered C2 , I wouldn't run any less than that for rear offset.
Old 12-20-2022 | 09:26 PM
996AE's Avatar
996AE
I run 6gt3 wheels on my 996 narrow body 295 35 18 rear no problems lowered PSS10
Fronts 235 40 18
Old 12-22-2022 | 06:18 AM
hardtailer's Avatar
hardtailer
That is not entirely correct as where the outside edge sits is also dependent on the wheel width.
ET is defined as the distance between wheel flange and wheel centerline.
As such one needs to know both ET and wheel width in order to calculate where the outside and inside wheel lip are.
The following 2 users liked this post by hardtailer:
damage98MO (12-23-2022), EVOMMM (12-22-2022)
Quick Reply: 295/30R19 on narrow body 996?
