I have the identical setup. Bought my ohlins second hand, barely used in immaculate condition. Had them installed by an shop and have clunking to the front right on my C4S. Unfortunately my car is away for the winter so will have to wait till the spring to diagnose.
subscribed to see if you come up with any solutions I can try!
He's got to get the preload corrected (it cant be correct since the spring is loose), then slide the bracket up then tighten everything together. then make sure both sides have the same ride height (lower dimension looks like a 3 but I can't tell)
Correct. It's a three (3). Thanks for the feedback.
So I got the answer from Ohlins. In short, the retrofit setup has different installation instructions than what you find online. Here are the correct instructions that refer to the same diagram I posted above on 11/14/22. Notice that there are no lock rings below the lower spring seat and above the anti-roll bar mount.
You need to add 10mm of preload to the spring, you currently have negative preload on. The spring will measure 190mm long once preloaded. The car needs to be off the ground to do this. Below- Once you have the preload set you will then run the anti roll bracket up to that lock ring securing it in place so that the lock ring does not move. They need to be touching. Below- Once you have that the bracket secured you will then run the second lock ring up to the bottom on the bracket. Below- Then you will leave 3mm gap to the third lock ring that sets your ride height. Below- If you really wanted to go lower, you can remove this lock ring and have the upright set against the second lockring for reduced ride height. You can gain about 5mm of height adjustment if you did this.
Still waiting for Ohlin's reply to my email.
Do you mind sharing your contact method for Ohlins? I came across the recall notice and am under the impression the original owner did not apply for the recall. Now I have them install on my car and would love to find out what my options are for getting the front struts replaced as they are second hand.
Not at all (as long as you trade me your white C4S for my silver...).
I started with emailing the US company at (ohlins_us_info@driv.com), and ended up getting a reply from gary.christopher@driv.com who proceeded to handle the claim for me. BTW - they didn't care that I was not the original purchaser, but they did want to know where they were purchased originally from. I was able to provide that.Be prepared, you will need the following information for them:
1. Full name
2. Shipping address
3. Phone number
4. Vehicle Identification Number
5. Image of part number at base of front struts and top nut above mount. (Just a quick photo down by the lower shock mount. Numbers should be easy to see)
Good luck.
