01 Cab top won't close.....
I left the top down on my 01 Cab last nite and went to close it this morning to go to work. I pull up the emergency brake, the light (fro the ebrake) goes on in the dash. I press the button to close the top, the windows roll down, then I hear a click and the light in the dash blinks (for the top)...
I check the fuse, and I checked to make sure the hood wasn't left half open (weird thing is I had the front hood open to put stuff in prior to starting the car) - still the same thing happens....
Any ideas on what else to check before having to take it to the dealer? I remember reading stuff about this but my searches come up empty!
THanks in advance,
Will
THanks in advance,
Will
Anything else I can check? The fuse is fine...I've opened and closed both the front and rear hoods....nothing appears to be blocking the physical operation of the top... anything else to check?
Thanks,
will
Thanks,
will
I just got home and tried the entire process again with the windows up. Its starts off with the windows coming down, but they don't come down all the way...and then the light in the dash starts blinking....when I press the button again, then the windows go down the rest of the way, but then the light in the dash continues to blink....
Hopefully that gives some more information!
THanks,
Will
THanks,
Will
THanks,
Will
THanks,
Will
Well worth it...
