Clock Spring/Horn Contact Assembly Needed
Does anyone have a spare clock spring / horn contact assembly / contact unit for a 996 3 spoke airbag steering wheel?
Thanks...
Thanks...
It does not matter on a 996/Boxster if it is for a 4 or 3 spoke. What may matter to you is that the one for the tip has 2 extra wires for the shift buttons on the steering wheel. So, if you need the 2 extra wires then you need the one from a tip.
2 of our local guys have replaced the manual transmission version with the tip version because the now have a tip steering wheel on their manual transmission car. The tip shift buttons are used to control the trip computer.
Might try the wanted section of renntech.org since that is where we do our local work on cars days. Jeff
