I was replacing the starter on my 996 and before removing the starter I noticed a loose electric connector just dangling near the starter (images attached). It doesn’t seem to connect anywhere and was not part of the steps I took to remove the starter. Any ideas and where it goes or what it does? Connectors position with starter removed Connector numbers Connector removed from wiring harness
Thanks for the notes! The car is a manual so would make sense that it is unused if it’s for the tip. I left it alone tucked safely like it had been before and after putting everything back together car runs perfectly fine just as it had before.
