front drop links for gt3 bars
Anyone know if these will work instead of the uber pricey TRG ones? they appear to be the same. Thanks all I also have a pic of the trg ones and they seem quite simular but the length is an issue. I could however cut them down if they're a little long and it would seem sufficient. thanks.
attached are the trg drop links and the link is for the ones I am thinking about using. thanks again,
http://www.tweeks.com/shop?frame=3.68.2274
No those links are really small and won't accept the bolts for the struts. they were design for the 65-89 cars with bolts no larger than 8 mm shafts. If you did not buy bars yet try the H&R they are similar in size to the GT3. Another suggestion is to ask FVD they make there own bars and might have a link that will work.
