996 Forum 1999-2005
How to fix this please
Old Mar 15, 2022 | 09:10 AM
Sen Sengo Tseng's Avatar
Sen Sengo Tseng
Default How to fix this please
Vehicle:
Customer:
Operator:
Date(D/M/Y):15/03/2022
PORSCHE_EN_TEST_00022>911 (996)>Smart Scan>AB (Airbag)>Read Fault Code:
Total Number : 1
0021 1/1
State: None
Ignition circuit, driver
Old Mar 15, 2022 | 11:44 AM
De Jeeper's Avatar
De Jeeper
Is your air bag light on? Have u unpluged the electrical connection on the seat belt and turned the key on? Its hard to tell what is wrong because there is no code number.
It may be just a glitch or u have an airbag that is not reporting to the computer. Seatbelt connections can also cause faults.
Old Mar 15, 2022 | 12:02 PM
Sen Sengo Tseng
yes air bag light is on.
Old Mar 15, 2022 | 12:28 PM
De Jeeper's Avatar
De Jeeper
It may be a bad connection to the drivers airbag. If u turn the key with the airbags or the front seatbelts disconnected then you will get the light and fault. If nothing is disconnected a better scanner is needed to pin point the location of the issue but it may be as simple as a loose connector.
