996 Forum 1999-2005
New Squeaky brakes
Old 12-30-2021 | 12:15 AM
GrafSix's Avatar
GrafSix
Default New Squeaky brakes
I bought my 03 Porsche 996 TT in sept from an indy shop that replaced the front rotors and brakes. It sat for a month or 2 before it came to me and I have been driving it round. The brakes squeak though and I was hoping after driving it hard it would go, but no. Is there a way to get rid of it with out taking the brakes apart? If I do have to, is there anything I need to do so I dont put them all back together and find they squeak again? Any advice greatly appreciated, thanks
Old 12-30-2021 | 10:22 AM
Coussa's Avatar
Coussa
what pads did you put on? I replaced my front brakes on my C4S (same brakes as the Turbo) with Brembo discs and pads and have the same issue. My specialist that I use for bigger jobs advised me the Porsche OE pads have a special compound to remove the squeaking so I’m stuck with the noise until I change them next time. I guess sometimes the Porsche tax on parts is worth it.
Old 12-30-2021 | 10:47 AM
De Jeeper's Avatar
De Jeeper
Sometimes its the pads, sometimes the rotors? Were the dampers on the pads replaced? If not many have reported that they do make a difference.
Old 12-30-2021 | 03:14 PM
P9C's Avatar
P9C
^ That
I put these -> https://www.fvd.net/de-en/FVDBSK3529...996-c2-c4.html and I haven't heard any squeaking. If I would have to guess check those dampers and make sure that they are correct ones and installed properly.
Old 12-30-2021 | 06:23 PM
Coussa's Avatar
Coussa
Originally Posted by P9C
^ That
Those look to be OEM Porsche pads so if installed correctly won't squeak. I used Brembo pads and they squeak even with the dampers properly installed. Lesson for me was, buy OEM pads from now on. Since the breaks work I won't rush to replace them right away and will wait for spring maintenance to swap them even if not completely finished.
Old 01-01-2022 | 01:57 AM
TheChunkNorris's Avatar
TheChunkNorris
I didn’t realize the fit kit was old and I swapped them all… hopefully it’ll quiet the brakes too.
Quick Reply: New Squeaky brakes
