996 Forum 1999-2005
Engine
Old Nov 18, 2021 | 01:29 PM
rcipriani's Avatar
rcipriani
Default Engine
Can I start my 1999 911 engine with transmission removed and engine supported by Porsche support bar used to remove transmission?
Old Nov 18, 2021 | 01:47 PM
JohnCA58's Avatar
JohnCA58
It shouldn't be a issue as long as the flywheel remain on the engine for the starter and engine position sensor to read,
Old Nov 18, 2021 | 02:03 PM
De Jeeper's Avatar
De Jeeper
Also make sure the harness and hoses r secrured so the flywheel doesnt grab them
Old Nov 19, 2021 | 08:18 AM
cdk4219's Avatar
cdk4219
Probably have to bypass the clutch switch, I don’t think the Slave cylinder will like the pedal depressed without clutch fork back pressure?
