Camshaft Position Sensor Location (P0343 Code)
Hi everyone, I have a 2002 C4s and I'm getting the following code: P0343 Porsche fault code 112- Phase sensor 1 (camshaft Hall-effect sensor 1)
Can anyone guide me to the location of this sensor? I have the air intake off and looking in, under and around I'm seeing nothing that resembles the sensor.
Thanks!
Thanks!
Sorry i do not hopefully one of the guys that have pulled that motor will chime in.
found this, its bank 2 but bank 1 should be in the same position but the head is rotated 180*
https://www.6speedonline.com/forums/996/395583-996-p0349-camshaft-hall-sensor-replacement.html
I just changed both my cam position sensors on my ’03 3.6. Passenger side one can be accessed from under the car. Like the 6speedonline post, it’s tight but a short allen key will get it. Drivers side I did from the top. Removed the airbox, then sort of pushed the cooling lines aside and wrestled the bolt out. I found a hex bit with a ball end, on a 1/4” ratchet could be squeezed in to get it most of the way out, then fingers from there. It’s tight but manageable.
