Should i expect lithium boost pack to open hood?
The manual override is the
button on the front.
Oh, the button on the jump battery, got it!
Premium Sponsor
You guys should also realize the NOCO GB40 has a very small Battery in it... But our Antigravity XP-10 would do it with no sweat at all.
We actually make a kit for allowing you to open your frunk of Jump Start your car if you get locked out. Its compromised of a harness kit you plug the Jump Starter into.... But then again we make a Battery with Built-In Wireless Jump Starting so you would never need to Jump Start your Car again.
This is the wiring Harness... you can use it with most Jump Starters like our MICRO-START Model XP10 or other brands.
https://antigravitybatteries.com/pro...s-msa10b-long/
XP-10 Antigravity Jump Starter- " Consumer Report "Best Rated Jump Starter..." https://antigravitybatteries.com/pro...s-msa10b-long/
Anyway it give power directly to the battery terminals so you have the energy to pop the hood easy or jump start it.
And yes the depending on the model of Mini Jump Starters and the internal Battery size they will easily supply enough current to pop the hood on a Porsche. But it is often harder to get a good connection on fuse panel and a good ground. Also several of the MIni Jump Starters won't turn on if they don't see voltage as a safety precaution.
Antigravity Batteries Clampless Harness for MICRO-START or other compact Lithium Jump Starters.
